Suspension / Wheel torque settings, please help asap
(In Topic #86335)
I'm changing the springs on my MK1 today. I searched everywhere yesterday for a Haynes manual but nobody stocked one so I'm unsure what the torque settings are..
So, if anyone has a Haynes handy I'd really appreciate it if you could tell me what the wheel bolt torque settings are (standard wheels) and what torque settings I need to use on the various suspension bolts (not sure what ones there are until I look)
Adrian
<a href="http://www.demonvw.co.uk/forum/viewtopic.php?t=14992">My MK1 GTi</a>
Cant help with other bit but sure someone can just do it as tight as you can i would say without going ott.
Dub76 said
…just do it as tight as you can i would say without going ott.
That's what I thought of doing, that is what I usually do and used to do on my MK4 Polo, do it as tight as possible but knowing where the limit is and be a bit sensible.
Thanks for the wheel info
Adrian
Web Team
Figs in Nm
strut to body..20
strutbody to piston rod..80
wheel bearing housing to stru..80
tie rod to strut..30
bottom ball joint to wheel bearing housing..m8..30..m10..50
bottom ball joint to wishbone..25
driveshaft nut..230
front wishbone bolt..100
rear wishbone bolt/nut..5
antirollbar to wishbone..25
Ebay would be a good place for a haynes :cry:
Am keeping an eye on a couple Haynes on eBay at the moment will hopefully win one
Adrian
Was looking on there for something else the other day and seem to remember seeing some. Even have second hand ones avaiable as well
pm'd ya matey
......golfless......for the moment
Hello, first post .ew said
Had a look in my haynes……
Figs in Nm
strut to body..20
driveshaft nut..230
Sorry for bump this old post up, but i don´t want to do new one. I have little problem with rear wishbone nuts, are they really 5nm ?!? They are ?17mm nuts?
Same size nut are on rear beam and they nm is like 60-70nm
Sorry if my english ish not perfect My own language is finnish.
The Haynes does say 5, but it is a printing error, and it should be 45Nm. This can be worked out because the lbf ft figure is correct at 33, and that equals 45 Nm.
Lee
2001 Zafira 1.8
2001 Zafira 1.8
