Suspension problems!! My cabby is terrible atm HELP advice needed!!!
(In Topic #159504)
Ive made the novice mistake of buying cheap 200 pound coilys, and to say the least the ride comfort is terrible if not on a nice flat tarmaced road.
Theres some GTI struts and eibach springs i know are up for sale of a 1983 cabriolet, the advice required is will they fit my 1993 standard 1.8 cabby??
and anyone think theyll ride well?
There in very good condition.
New to Golfs - All Help Appreciated!
worth fitting some new strut tops while the struts are out the car (you will need spring compressers)
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=running-gear_2%2Feibach-pro-kit-springs
The ride is pretty bad, scuttle shake is terrible on rough roads. My tyres are 165/45/15 so that doesn't help, neither does the 45psi pressure I need to help prevent pothole damage to the wheels.
I'm re-thinking my wheel/tyre and suspension setup now that I'm getting older and want a more comfortable mk1.
Has anyone found any good coilovers which aren't too rough on ride? I have a 1998 Audi A6 on coilovers and the ride is sooo much better, I can actually depress the suspension on the corners and it's not the tyre deflecting! The A6 has FK's.
It would be nice to keep it on coilovers for the adjustable stance, however if it comes to it, comfort will prevail I think and shock/springs may be the way forward.
*Evomaster3000*
A freind recomended these, not sure on how good they are bit he was pleased!!!
