Steering - Wanderer
(In Topic #83970)
Steering - Wanderer
Help - + 2 more issues - 1 electrical & 1 poppy out reverse!!
Thx all 8O
Popping out of reverse is a common issue. Probably just need to adjust the linkage. Have a look at the state of the linkage bushes while you are there & replace if necessary. Cheap and relatively simple to do and will improve the gear change no end…
I'm thinking, the steering's gone really light because the breakage has misaligned the steering and put it into zero castor angle. And that after the 10% turn, the loading during turning puts the suspension into a different alignment giving you +ve castor once again.
It could be any of the wishbone bushes or the top mounts. So its worth jacking the wheel up and giving it a good tug. If steering wheel inputs give you wheel turning, then the steering's still okay, although of course track rod ends and UJs in the rack can wear. Its very unlikely to be a steering gear cog, unless it was seriously under-lubricated and abused earlier in its life.
I will advise as to wether this cures it but it's certainly stage 1.
Thanks for the suggestions.
PS - everything else is all tight and good!!! :wink:
IIRC someone thought it's more likely to happen if the car is lowered.
marketdrayton said
Strange, i thought the tyres may be (along with lots of other potentials). Had it up on a ramp at 7am and there's trouble. I am no mechanic, but the big steel arm on n/s that is welded to the chassis has snapped. When you accelerate it pulls one way and let off goes the other! It has been welded previously and will be done properly this time. Anyone else heard of it? Had it? Passed an MOT 3 months ago fine?? Which concerned me!
Which arm is it? Is it the one which supports the wishbone lower mounting points?
