Steering and Camber settings??? HELP
(In Topic #101282)
Need the tracking setting and most garages don't have the settings for the car!!!!
Getting it done at lunch time so please help!!!!
Tim.
Regards Volkswarren
I run around 1-2? of negative camber, and from memory about parallel on the tracking, and the handling is fine.
HTH
Rich
Just have to find a garage that'll set camber for me now!! Is there a cheap tool / gauge out there for setting camber?
With the car on level ground, loosen off the camber adjusting bolt on the suspension strut on one side, and set it so that the wheel looks about right from a distance (i.e. slightly pointing in at the top). Lock it off and make a note of where one of the points of the bolt goes (e.g. the point of the bolt where the eccentric washer is smallest points towards the caliper, or whatever).
Then loosen the bolt on the other side and copy the position of the point of the bolt over. Tighten up, give it a quick visual inspection from the same distance, and you're done.
HTH
Rich
camber
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
The correct angle for the camber on most early Golfs is 20minutes negative but you should always check with VW the correct setting for your vehicle. You do not do this setting with a spirit level and eye. More on this a bit later.
Out of interest what should the tracking be set to? I assume parallel is good?
The general setting for the track on most is 0 deg but again you must check with VW or your handbook for the correct for your vehicle. Road test again completely as above and check the track setting
You can now see that this whole operation is not something you can play at and is very time-consuming to get right. My man who gave me all this information takes 3 hours
