Squeeky squeek....
(In Topic #110140)
Squeeky squeek....
Basically, when I change gear and the body of the car 'pulls back' as it were, or if I go over a sharp speed hump and the car bounces a little, a loud squeeking comes from the front of the car as it 'bobs' up and down. (A little like this: eeh-EEH-eeh lol). I'm thinking it's either something to do with the suspension or the engine mounts (but then I am pretty clueless). Can anyone suggest what it might actually be please? Hopefully it's something I can sort myself.
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
Use a rubber padded jack and carefully lift the engine a little close to each engine mount. Observe any severe play in the mounts while lifting, i.e. does the engine lift without without the chassis/body lifting.
It could be the downpipe, where it meets the manifold. I had this with my cabrio and it drove me insane. I changed the front engine mount and fitted one from a mk1 diesel (i heard they were tougher). All good with mine now.
Hope it helps.
Bez.
Thanks for your help guys.
I did one mount at a time and just supported engine with jack and wood blocks beneath sump. you shouldnt need to jack engine up as the bolt off and on in the same position.
Bez
