Sportline flywheel cover plate, which one fits??!
Hi,
I took my 1993 GTI Sportline (DX engine code) into Kwik Fit yesterday for 2 new front tyres and tracking to be done.  Whilst there I asked the mechanic if there were any glaring issues underneath.  He told me that there was a gap between the engine and the gearbox where the flywhell was clearly exposed and thought there should be a plate covering it.
Anyone know if I am missing a part here that I should look at finding and fitting?
Cheers,
Del
Yes you need a cover plate for it.
I believe your box will be an 020 code, I'll see if I have my old cover plate kicking about later if you like?
Cheers mate, sounds just what I need. I will see if I am able to confirm the code but definitely a 1.8 DX engine attached to it.
I'm in the garage later anyhow so I'll see if I can find it.
In the meantime someone should confirm for you!
This be it.
Can anyone confirm that this'll fit for a 1993 sportline?
Cheers Raul, if it does fit I'm interested.
I couldn't find the code on the car or in the docs. Just found a code for the transmission which was AUG.
I've changed the title to try and help.
Come on peeps help a brother out! ;)
if its from a 1.6-1.8 mk1/2/3 with an 020 gearbox, it'll fit a 92 sportline ;)
note this piece is a later revision, early cars the tin plate between box and engien was all one piece which made sump removal a bit of a git. so vw lopped the bottom off and made this plate. sump swaps still a git, but ever so sligtly less so :lol:
How do I tell if I have a 020 box.  Is there any code I can have a look for under the hood?
The car was manufactured in 1992 with a 1.8 DX engine and has a 5 speed manual box.
yeah sorry its an 020 box, any manual mk1 1.5-1.8 will be 020 :)
I have my gearbox out at the moment, my gearbox code is AUG too and my flywheel cover is part number is 068 103 648. Hopefully that should confirm it for ya!
My plate has 020 stamped on it if you look real close at the furthest mounting hole to the left it has 020 stamped there. :wink:
If you want it shoot me a pm dude.
Yep, the plate on mine has 020 stamped near that hole too, Raul's should be the one!
Yes, also if you look at my pic it has that same p/n stamped in the middle.
Cheers guys! Looks like it's what I need.
PM sent Raul
I have no pm, I'm pm'ing you now. :wink:
