Spline adapter removal - how?!?
(In Topic #145818)
I've spent all day trying to remove the spline adapter from my Clipper.
I placed a pair of mole grips behind the 'ridge' on the adapter and tried hitting them with a hammer. I then gave in and went and bought some 4" 2 legged pullers but I have had no luck with these and they in fact began to thread the column. I guess I should have bought the larger pullers.
Can I saw/grind off the adapter? Will a blow torch help?
I will certainly not be putting it back on, I just want it off.
Take it you used pullers and they just slip off!
Saab 93 diesel daily
Took some real cranking before it popped off.
Make sure the pullers aren't worn as it will just slip off the adaptor.
Borrowed one from a local garage and threw them a tenner.
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
All MK1 steering columns are the same aren't they? Just later models had that adapter attached?
but ya, earlier mk1 column will do ya
I tried hitting it again and no joy, though I did manage to break a slab lol. I even tried hack sawing it just after the toothed part in hope it would in some way help. It did not.
I gave my angle grinder to my mate with a rather rusty Uno Turbo, he needed it more than I lol.
Original spline is 17mm yeah? I've got hold of a old Mini wheel from my mate, I just need a boss for it. Will a cheap one from eBay such as this be OK?
http://www.ebay.co.uk/itm/Volkswagen-Beetle-Golf-mk1-mk2-Polo-Scirocco-Steering-wheel-boss-hub-adapter-kit-/170857505442?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c7e6a2a2#ht_2470wt_1037
