speedo drive lost in gearbox !!!
(In Topic #112375)
fished it out about 4 times but could not get it back in to the hole it seats in.
the last time i dropped it disappered ! can not see it any more.
what should i do ? i have been out in the car all the gear are ok ! whats going to happed ??? can the end of the gear box be taken off ?
if the drive was worn to the point of not staying connected to the cable then it's time to change it anyway. i know of people who have left a dropped speedo drive in the bottom of the box but do you really want to chance it?
get a mini grabber and go fishing is all i can suggest mate.
should i get a air line in there or will it push it more in to the gear box ?
even when i get it out i can not get it back in !!!!!
you could have had it for less than ?5.00
paul_c said
Why didn't it fit properly the first time?
not sure .it would not go back in to the small locating hole drilled in to the gearbox all looks ok in there,had about 4 goes of getting it in,each time i could fish get it out,i have ordered a new drive but can not get the other one out
thanks
draining the oil
having a look
going for a quick spin
draining the oil
the small circlip is missing from the bottom of the cable so i am not sure how i'm going to get the new speedo drive in,new cable ?
thanks for the help
james
N 900 154 01 - 0.15+VAT
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
jools182 said
how did you get it out in the end?
used a lambretta inner rear brake cable,pushed it in were the speedo cable goes in,the brake cable is about 3mm thick but flexible so you can bend it and still get some force on it
got the new drive in today,all ok
