sounds like a gun going off
(In Topic #93367)
could the drop of damaged them? it pased mot straight after.
of am i barking up the wrong tree and should be checking bushes ect?
cheers tom
ideally you need to match dampers and springs, if there is signs of leaking then they are knackered, you can get a nice Bilstein or Spax, Boge lowering kit for less than ?200 it all matched with shortened shocks and uprated springs or you can get the new Koni kits which are dearer but obviously higher end quality
like you said dampers sound like they need replacing so go for a matched setup, ie all standard or all lowered.
duff
good
1988 1.8 carb Golf Clipper
