Scraping noise when turning left, please help!
(In Topic #89747)
This is my first post, i've owned my mk1 cabby for 6 months and she's costing me a fortune! having just passed her mot she's now making a horrid scraping noise. This only happens when i turn the steering wheel fully to the left. I would really appreciate some advice as i adore the car and want to keep her up together and on the road.
double check theres not the remnants of a cokecan or dead bird up in the arch tho eh!
rebuild in progress....
Park you car on full steering lock and have a look at the rubber boots on the drive shafts. If they are split, corroded or come away, that will cause the grease to get washed away from the CV joint and cause your symtoms.
jack it up and spin the wheel then try it at hard lock, its more likely to be the wheel end one tbh.
tho i truly thought an outer cv was going and it turned out to be a wheel bearing, all the symptoms were the same, so wiggle the wheel back and forth to check for wheel bearing play as well.
hth
