Saggy back end
(In Topic #74782)
Guest user
Saggy back end
The car sags really badly when full of fuel and a 9st person+ shopping on the rear seat.
The replacements for my old broken pair came from GSF, is there a difference between front and rear, could front ones have been fitted by mistake?
So what gives?
paul
Guest user
I suspect that GSF supplied tintop rear springs because they have a much softer rating (the cab weighs more)
Did the cab and the tin top have different rate springs?
My Build Thread
Incidently, Jetta and Mk1 Cabrio's share the part number. GPC can supply but at almost the same cost as a VW dealer at approx. ?55 per spring so no advantage there.
I did mention that the springs had been changed after I found that both sides were broken-the bumpstops were replaced as a matter of course.
The cab still handles OK and we drove across the Pyrennes this June through the twistys without drama. However, I prefer not to drag the back end along the deck and it was a bloody waste of money fitting the wrong springs-thanks GSF!
Tim
Control functions:
