Rumble Rumble Rumble....
(In Topic #72214)
So myself and my mechanic have checked the wheels & tyres and swapped the fronts for completely different sets, have also checked and found no problem with the off side outer cv, wheel bearing, track rod end, lower ball joint etc etc. Still no idea what the problem is.
My mechanic is suspicious the offside inner offside CV is knackered or even the gearbox is on the way out, the latter I find pretty hard to believe, but am open to ideas. I thought sticking a lower strut brace on would stiffen things up a bit in case it is the chassis flexing therefore compressing the drive shafts & gearbox output flanges, although am yet to get one.
Anyone else experienced any thing similar or know what the problem might be?
Thanks…
_____________________________________
83 Golf GTi Campaign - Diamond Silver - Light mods
83 Golf GLi Cabbie - Mars Red - Heavy mods
My Build Thread
To check a CV joint put the car on full lock and drive around in a circle slowly. If you hear a load clicking sound then the CV joint is on it's way out.
However, you won't be able to hear/feel anything with the car jacked up, as there is no way that you can put the kind of side-load on the hub with your hands, as it gets when driving.
It could also be a CV joint, but less likely. If you're feeling energetic, you can disassemble the CV joints for a look (can't do this to the hub bearings).
How many miles are on the car, and do you know if the CVs or hub bearings were ever changed already. Also, did it ever fail an MOT for broken CV boot (implying that the CV joint may have been driven without grease for a period)?
almost came off :?
1984 white s2 golf gti , 2006 golf gti
Best to replace both front bearings at the same time, I did one, only to have to replace the other 3 weeks later !!!!
Life Member
Honestly! I had exactly the same symptoms on my old 1600 GTI.
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Cheers.. - Will post n let you know what the problems were….
