ronal aero 16" will these fit my cab
(In Topic #133550)
http://www.ronalwheels.co.uk/?page_id=41
but i am worried they may not fit as i am sure they are at the limit size wise for a cab? i have it lowered by 30mm can anyone advise
thanks
adam
G60 cab!
thanks for advice
G60 cab!
http://www.tunershop.co.uk/popups/220836/0/Ronal%20Turbo.php
they come in the correct offset too.
G60 cab!
My car is lowered 40mm and no rubbing.
Good luck! 16s look the nuts…
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
Forgot to say that I rolled my arches. Took me 1/2 a day to do but well worth doing and pretty easy.
so if i want the rears to stick out a little more i need bigger spacers?
G60 cab!
I needed 10mm spacers on the front to clear the calipers.
Not sure where you are located, but I went to top gear in bridport for the fitting. It took them 2 hours to get it right, but they couldn't be more helpful.
If you're not too far away, I'd defo recommend them.
Speak to Justin.
Go for it and let's have a look.
T
Tian do you have any pics of them on your car?
Cheers adam
G60 cab!
id also put 195 40 16 on them
4x100
et 30 7.5 x 16
whats the thoughts
G60 cab!
