reverse light switch /mpg gauge
(In Topic #74885)
Does anyone also know what re-wiring work is needed if your car currently has the small 2-connector reverse light switch fitted and you want to go back to the large block connector?
ta very much
does it also make the economy/mpg needle work?
Yes - it switches in 5th gear enabling the guage
If you have an MFA dash liklyhood is either the box or dash has been swapped at some point. If it's just the box then the dash and wiring are there and you need the correct box with the appropriate reverse light switch block i.e. 9A box
Does this mean there should be a big block connector hanging loose somewhere around the top of the gearbox if the loom is the original?
it could have been chopped off though, couldn't it?
I had a quick look earlier before I read you're reply and that's how mine is currently
anyone who has a car with the large reverse light switch tell me if it is connected to the loom using that same thin plastic connector (that dirty bit in the background)
Item 31 is the swtich part located onto the gearbox housing. 35 & 36 are the connector and rubber housing.
I think this is different to yours.
'83 Helios Campaign Gti
Hopefully it and the wires will still be there, don't know what to do if not.
Where are those pictures from if you don't mind me asking , I could do with a set of them
