Residual Valves - Rear disks ??
(In Topic #107646)
Going to be running a twin master cylinder pedal box with a rear disc set up without rear brake compensator valve set up on the beam and using a adjustable bias inside the car to set up the pressure to the rear brakes,
What I need to know is, when I striped the car down it had these two residual valves? (I think) just behind the front seats going to the rear brakes with the set up above will I still need to use them or can I just run straight pipe to each caliper. or do these play a important job??
Also if I do need them. Now I have them out of the car cant remember which end is front to rear line in line out ? ops:
75 golf L 4 door Swallowtail
78 Custom 2 door Swallowtail 1.8T
02 Mk4 Anniversary GTI
07 Mk5 Edition 30 - stage1
Thats what I hope just wanted to check first, thanks for the advice.
Another problem solved 1 step nearer being on the road again!!
