Rear wheel cylinder bolts....aaaaaaarrrrrrrggggggghhhhhh
(In Topic #94748)
Any suggestions of how to get these bolts out? They are seized and to top it off they are allen key headed so these have obviously rusted and rounded off.
Don't you just love old cars…..
Overwise try;
shocking the bolts with a hammer blow,
molegrips
hammering in an oversized star or Allen socket
hammering on under sized normal socket
heat up with blow torch (watch out for brake fluid spurting out at high pressure and burning)
Rear cylinders on MK1 are almost consumables, changed loads becasue they have either seized solid or peed out gallons of brake fliud ruining the shoes.
If and when my glamorous asssitant arrives this afternoon I'll be joining you grappling with 20+ year old rear flexi due to a MOT advisory. :roll:
1983 1500 GL Resto
2003 Leon Cupra
2003 Leon Cupra
My glamorous assitant didn't trap so started on my own and after about 1/2 hour remembered why I didn't do this before when it was an advisory from last years MOT.
It is impossible to get at the flexi to solid brake line connection above the axle. Also in the small amount of movement that there is the metal pipe is turning with the threaded bit…. The one on the body to flexi came part in about 30sec.
Thinking I'm going to drop the axle to give some spanner wielding room, hoping it shouldn't be too bad as a garage had it off about 5 years ago to flush the tank.
Its one of these jobs where the longest way is actually the quickest.
I remember there being very little room because of the fuel pump, accumulator and hoses in the way on one side but I think the later cabrio tanks are bigger/different shape and take up more even room??
Early-1800 said
Yea, I remember it being a pig of a job when I restored the GTI, but that was 8 years ago and had the axle off to refurb it and to get the tank out, so poss I fastened the flexis on to axle whilst it was off the car :dontknow: .
Its easy enough to unbolt and drop the fuel pump out the way while you're doing the brake lines.
Didn't read this before going out this morning but ended up doing as suggested; rear drum off, drill and crack off the cylinder. Finding new bolts was more of a hassle than smashing the old cylinder off (less enjoyable too! )
