Rear suspension lower strut nut and bolt.
(In Topic #113536)
As per title, does anyone know what size these bolts are?
The nuts are 17mm.
I have replaced my rear springs and need to replace both bolts, assuming these are readily available from VW dealers?
The nuts are 17mm.
1983 Campaign, BRMotorsport152
The bolts are M10x70. VW part# N 010 470 7
I'm pretty sure they're supposed to be fine pitch thread though. There's 2 variations of fine pitch on M10 bolts in common use - 1.00 and 1.25 (normal pitch is 1.75mm). Also there will be a strength rating probably higher than regular, since its a suspension component.
Tks guys, very helpful, especially the part number, should make life easier talking to the parts dept in the morning...cheers.
Part was ordered yesterday and fitted today.
Just in case anyone else needs any of these bolts for the rear shock mount, I was informed the part number has been superceded by;
N010 47 01.
N010 47 01.
