Rear suspension bushes
(In Topic #74613)
Also has anyone fitted polyurethane bushes to the rear? are they worth the extra money (assume would need to the front as well)?
1983 1100 C
1983 1100 C
All still available from VW but not cheap i used genuine bushes on the roll bar and polyurethane bushes on the axle mounts . Makes the car feel much better but that may be down to being new i have since found out that you can buy all the bushes from some where like http://www.bigboystoys-uk.com/ so it might be worth a price comparison to see what works out best .
When reading a restoration article in one of the many VW mags it stated that the rear axle mount bushes due to so little movement never need replacing but the rest do ? They are a pig to remove and clean up .
Cheers……
Bugpack ones look quite affordable (anyone used these?). GSF have a mk1 golf poly bush kit listed at around ?65, not sure who makes it will have to check it out. The rear axle hinge bushes do have a few cracks in them - suppose its best done while I've got the axle off :borg:
1983 1100 C
1983 1100 C
Assume you meant this http://www.bigboystoys-uk.com/ link - other was for the 'Quadzilla', looking at getting one Chudd
Ammended ops:
Cheers………..
You'll need to cut the old rubber bushes out of the brackets and get rid of the rubber that's left with a wire brush on a drill. Bit messy but not difficult
Cheers,
Mark
Ali
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
If anyone is after Poly bushes then we sell SuperFlex ones. Not as cheap as Bug stuff but cheaper than Powerflex, and better quality too !!
Turbo - what is your price for the rear and front kit? Cheers
AliCabrio wrote:
…you'd have to open up the beam, replace the nut, then weld it all back together again
Sounds like fun
1983 1100 C
1983 1100 C
mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
