rear o/s drum binding?
(In Topic #141919)
took ages to get the drum off
tried adjusting the piston and the shoes to no avail.
finally got drum back on. now even worse binding
please help
p.s. n/s spins lovely
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
Try adjusting both sides till you hear them rub slightly when you spin the drum.
I would also give the shoes a good rub down with a bit of sand paper.
Its possible its something else at issue, if they've just started binding…..is your handbrake cable adjusted properly (ie backed off fully when the lever is down), etc .
I know that my friend should really sort it for me but he is about 10 miles away plus i could do with learning!
OK this is a photo of the good side that spins freely
when i adjusted the other side all o did was try to move the shoes in a way that would stop them rubbing the inside of the drum.
paul can yo see the self adjuster in this photo, so i can check the one on the other side?
