Rear camber shims
(In Topic #152565)
I've recently purchased a set of rear camber shims for my cabby and was wondering if anyone has done the same. Ideally for cosmetics and for the wheels to sit under the arches a bit nicer on the eyes. I understand the repercussions so I don't need a lecturing lol. Is there a desired camber angle that anyone can suggest or is it a case of guessing. I'd like to tweak the fronts to enhance the handling too.
Any advice would be appreciated.
Would need pics to get a better idea.
depends on how far you want to go.
Gents are adjusted via bolts on strut so no problems there, ideally with 4 wheel alignment
Saab 93 diesel daily
Looking for a subtle negative camber like so…
Courtesy of GTI forum.
Or am I being ambitious…
Id go 1.5 degrees negative camber and see how it looks.
Cheers ill do that. I will get pics on when done. Wont be till i get my wheels resprayed though.
… Also make sure you torque wrench the hub bolts after fitting the shims
