Rear axle problem
(In Topic #72635)
Rear axle problem
The only thing I come up with so far is to remove a fair share of metal around and including the broken bolt. Weld a new bolt on the "metal piece" and then weld the hole thing back to place?!?
T.I.A
/Mike
-84 GTI Mars red (campaign)
-94 Audi S2 RS Avant
-98 VW Passat Variant TDI
I ll investigate more this evening to see which way I ll use to go about it.
/Micke
Try PMing him
He seems to be captain of snapping off bolts.
Peter.
1980 1600 GTI, daily driver.
Guest user
You will find in the boot that there are some taped up holes that are covered in seam sealer and painted over in the factory. You can cut one of these bigger to gain entry to the box section and weld in a new bolt, then weld the hole back up. I was respraying mine anyway so it all got covered up.
:idea: If anyone is removing the rear axle I?d advise cleaning up the exposed threads 1st and using lots of WD40 and turning the nut backwards and forwards until it is off. You have been warned.
Cost: 3 drills :/ , realized a bit late that I m a bit eager and are drilling with too high speed causing the drills to get dull in a matter of seconds. That leason is now learned
tnx
/Mike
Someone told me about that tape, but no matter how hard I searched (and I did !), I couldn't find it on mine.
Ah well, done now and new beam back on !
All the best,
Mark
but……. I did the same to my axle bolts… :dontknow:
Pic of the car itself:
and the engine:
I've discussed it with my uncles and they say I should just drill out the bolt and put in a new one from the top (through the hole) and just secure it with the axle and nut (not welding it).
Would you guys say that's enough???
And one can tighten the nut from the underside of the car.
if it's on stands i would not get in the vehicle.
and what happens if you have to drop the rear axle by yourself and don't have anyone to sit in the car when you need to remove it or put it back on?
