Real Coil Springs - not correctly located
(In Topic #132568)
"Rear coil springs not correctly located"
It has SPAX 40mm springs on the back, tester said that when car is jacked up the springs fall out of the locator, recommends fitting new springs.
Is this correct, or can this be fixed without spending £120 on new springs + £80, I read on the SPAX site that if this happens a shortened damper is required?
Any cheaper spring options? My sis has 3 kids and does want to spend a fortune getting car through MOT, how easy is it to DIY spring replace, I dont have a spring compressor is it possible without?
danny
She's had it almost a year, so first MOT she's put it through, its been SORN'd for a good 6 months. The springs were on it when she purchased it, in fact she still has the invoice - I'll check through the paperwork to see if the dampers were replaced too - I suspect maybe not.
What would be the cheaper route? To replace the correct dampers (I guess as it only failed on the rear, would need 2 dampers) or replace with standard springs (guess would need to do all 4)?
How do I find dampers that match the rear springs?
If the car is otherwise standard, then standard springs.
To be honest, we'd need to see the car - it should be fairly obvious if its lowered at one end or the other though.
Springs tend to cost a bit less than shock absorbers.
Sounds like a set of shorter sports dampers will sort it out.
You won't need spring compressors to remove as it has just failed on the springs falling out of their seats!
I had a set of cut springs on standard dampers in my youth. I took a roundabout rather ambitiously one day and the spring on the inside rear dropped out as the car was unweighted on that corner. As I came out of the roundabout, the spring didn't seat properly and nearly sent me spinning the other way! It can afect handling in a big way, which is why this is an MOT fail!
My Build Thread
