please help gear problem
(In Topic #89101)
hi people i have a big problem i need some help with, the problem is when driving my 1989 golf convertible its a massive strugle to get it in any gear. 1st is the hardest, the clutch is really stiff and only pushes down alittle bit but the cable was only changed 1 month ago by a garage but the problem i have now is that when the engine is turned off it will go in any gear fine but when i turn on the engine on i cant get it in any gear so i am unable to drive it any ideas off anyone would be brilliant please help
Did the problem go away when the cable was last changed ?
the clutch has always be very short and hard to push down and the gears hard to get into but now i cant select any gear when the engine is on but i can when the engine is off
have you checked if there is any oil in the trany.
if first you dont succeed. read the instructions.
cheers guys does anyone know of where i can pick up new clutchs cheep if i need to change it
