PD130/020 HELP
(In Topic #140322)
PD130/020 HELP
Would also like info on the wiring aspect if possible.
Scrub the rubber dub
wiring wise its same as any mk4 engine into mk1/2/3. strip old and new engien looms down, cut out engien specific bits from old loom leaving in sensor and wiper wires etc, do opposite on new loom then use wiring diagrams to combine the 2 looms together. its actually slightly easier on a mk1 than mk2/3 as the lengths of the mk4 looms are perfect for the mk1, the fusebox plugs all reach the mk1 fusebox area nicely. mk2/3 require the wires to be extended a bit
PD130/020 HELP
I did try the group N when i built the 2L 16V Turbo in 1994 but this just slipped! So the 4 paddled sintered group A was a better choice.
If you improve your engine spec then the 020 will suffer!
The cable boxes are better - 228mm clutches cope better than 210mm.
Regards
Mark E
ME926
