PASSAT 3 OUTLET MASTER CYLINDER PROBLEM - vauxhall brakes
(In Topic #111565)
1. has anyone used a 3 outlet cylinder before and how did they get around plumbing it up to work effectively?
2. Will the use of t pieces and extra brake lines greatly reduce the amount of brake fluid going to the drums and calipers resulting in no real gain in pedal feel?
There are four brake pipes present and i am wondering would it be better to buy a brand new 4 outlet master cylinder so the four pipes will bolt straight in without needing to put in t pieces everywhere.
i have all the parts needed to do a vauxhall brake conversion and want to ensure that the servo and M/C can give me maximum benefit.
any help or advice would be greatly appreciated
Dazzer
if i do use 2 outlets will the braking still be effective
cheers daz
