outer cv joints on 100mm driveshafts ?
(In Topic #94719)
Member 125 - 2005
Member 125 - 2005
paul c cheers for the reply but i must be tired or thick it's not sinking in tonight, i will have a sleep.. ops:
Member 125 - 2005
Helping a friend with her car and from what i can feel the 3 bearing prong at the end of the driveshaft (wheel side) that fits into the spherical cv joing has come away, effectively i can just feel the end of the shaft and running my fingers back i feel a notch. How do i get the 3 prong bearing back on if possible and what will of broke to let it off?! Is that a part i can get?
Cheers, can get photos if your not sure what im on about!
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
take them off put in bench vice, and bang on!
wether with 100mm inner cv shafts (rocco,cabby etc) the other cv (outer) is interchangable or specific? and where is cheapest for replacement cv's?
I've got a set of 100mm rocco shafts. As mentioned above the outer cv's have 2 sizes. My original GTi hubs would not fit the later outer cv's. The hub locked up solid as soon as you tried to tighten the hub nut.
I get the feeling VW / GSF only sell the later hubs now so they will need the corresponding larger CV's.
So to answer the question - No they do work with different hub, however the cv's can be taken off the 90/100mm driveshafts and are interchangeable onto other shafts.
HTH
