offsets
(In Topic #125950)
offsets
i currently have g60 steels which are either 35 or 38 and scrub the fronts. want new wheels but with a decent offset.
thanks. whats every one elseoffset with alloy wheels. splities/wide wheels mainly?
Saab 93 diesel daily
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
am i right in thinking they woul sit further in.
and if et45 for e.g! the arch would sit on the tyre!
what et would i be looking at with a 7"wide wheel. or do i try and keep it the same?
would not go smaller than a 195 tyre though
i do get some scrubbing on front and rear tho
or the et is giving handling problems?
car would be better with my vw bottle tops 6 x 14 back on but they don't look as good
thanks jonny for letting me know that my wheels should work ok, what size tyre did you use jonny???
i would of thought 1.5 degrees would be to much!!
i have mine set at 0.5 -ve.
i want it to hndle mint would you reccomend 1.5?
the back end is a bit twitchy on mine!! any ideas for that. i will be changing the subframe bushes soon and it has a strut brace. will be getting another which bolts to the chassis though!
I used one of those magnetic camber gauges though, so cant say how accurate it was. It was the same both sides at least
this is how it turned out:
have to jack it up and down so many times to get it right!
does it not eat through tyres?
thanks for the info jonny
anyone know what i have to do to get mini wheels to fit. pcd wise i mean?
want alleycats
what would hapeen if i were to fit a 13/7wide wheel with a et of -7. what would they fit like?
and another set with et7
thanks guys
