Official Wheel Alignment Specifications
(In Topic #143846)
I need to get my local garage to set the wheel alignment on my MK1 Golf but they have asked me to supply the relevant settings as they don't have them on their system.
They want a figure in "degrees and minutes".
I have searched through previous threads on here for the answer and have seen many statements that begin with "what I do is…." but thet's not really the answer I'm looking for.
Does anyone have the official degrees/minutes setting that I can give to my local garage so they get the tracking sorted?
All help appreciated!
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'93 GTI Sportline
Mk1'82 2.0L 8v
They are also local to me so if anyone does have the specs I can give them then it would be appreciated…
jinsta said
Go to another alignment gaff m8 (never had any issues with a Mk1 not being on the system for default settings)
They probably used to have them, but 'dropped off' the back end of the system because the Mk1 is so old now. I've seen parts listings which start at Mk2 Golf too.
The specs are in the Haynes manual, I'm sure I've typed them out more than once on here too. Keep searching, if you don't find them then I'll type them in again or maybe someone else has a Haynes handy? BTW they got the +/- muddled up but its easy to sort out which one is right. Set up the front with toe out, not toe in.
I do have a Haynes Manual and there is something there under "specifications" but it doesn't really resemble a degrees/minutes reading that the garage are asking for.
I don't have it to hand but it gives some reading in mm and then inches and follows it up with a quote of "or equivalent angles between 5' and 30'".
Basically it doesn't make much sense.
I'm sure you've typed this out before so sorry about this
If I can get a toe-in or out and a reading in degrees and minutes I'll be happy as Larry.
Cheers for your patience…
Website Manager
Camber - wheels straight ahead
Except 81kW models +20' +/- 30', max diff between sides 1 degree
81kW models +20' +/- 20', max diff between sides 30'
Castor (non adjustable)
1 degree 50' +/- 30', max diff between sides 1 degree
Tracking
Toe-out 5' to 30' (0.5 to 3mm or 0.020 to 0.118")
So thats up to half a degree (30') toe out on each side
Hope that helps
That has been a big help. Many thanks..
If they don't understand that then they're probably mad.
Cheers!
Website Manager
I have a 1.5 Jetta but it's lowered on Koni adjustables and Eibach springs
DubPartz
