O2J on a G60
(In Topic #138266)
O2J on a G60
I've a 02J gearbox left over in my garage after swapping my AGU 20v T engine for a G60 set up - minus its gearbox. If my thinking is correct, I can use this 02J 'box on the G60 engine as it will connect up to the mounting points in the engine bay, provided conversion mounts are on the gearbox. And will give me a box with more longevity and a better ratio set up to use on the engine than the 020 I also have off my original engine.
My real question after all that is, I want to keep the original clocks !
Which I'm doubting I can with this gearbox because of the need of the worm drive. I know on the 1.8T conversion you can get conversion kits to keep the original one's via signal from the ECU ? But with the removal of the 20v's more sophisticated ECU, can it be done ?
Doubting it can so there may well be an 02J box up for sale soon !
Cheers,
Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
Cheers,
Adam.
'83 MK1 Golf GTI
