No gear selection!
(In Topic #73541)
No gear selection!
Got it fired up today, started 2nd time and the engine is v smooth and rattle free. However, have problems with gear selection, sounds a bit like mattmk1?s problem. With engine off gears feel like they are being selected. However with engine running no gear can be selected, not even any nasty grinding sounds of trying to engage. If I turn the engine over in gear with the clutch depressed the car jumps forward, so obviously the gear linkage is able to select a gear.
Have checked clutch operation and free play and looks good. Run out of time to do any more - any ideas? :dontknow:
1983 1100 C
1983 1100 C
More unlikely but possible is that in extreme cases the rod that goes thru the box to operate the clutch can ?drill? its way through the release plate. This means that the pedal moves but doesn?t actually do anything. Does the clutch pedal feel like its actually moving something?
Did the car drive before it was parked up?
I suppose if no joy at least I'll get some experience of taking a box out e.t.c and for once won't have to worry about disabling my daily driver .
1983 1100 C
1983 1100 C
