NO DRIVE!
(In Topic #145562)
NO DRIVE!
All the linkages have been adjusted, and (it seems) that all 5 gears and reverse are slotting in nicely.
The only problem is, when I try to move off, the caddy just stays where it is? :dontknow:
Any ideas or solutions would be great, and the sooner the better, because I need to get to work Friday!!!!!!
Does the clutch feel ok?
Adjustment in the cable maybe but if there's no clutch at all I doubt its that.
Everything refitted yeah??
Could it be possible the clutch is fitted the wrong way, can't remember if this will atop the clutch from working.
is the new box a recon? Could have a pushrod/release bearing/release fork fault, located behind the green cap at the end of the box
Saab 93 diesel daily
possle said
Any noises?
The only noise I get is a slight squeal when I put my foot on the pedal.
Free play in the pedal is fine, feels good on the pedal as well.
Everything went together nicely, I got the friction plate all centered up. As for fitting the friction plate, the boss bit that projects from the middle is pointed towards the gearbox.
The gearbox itself was in full working order when it was taken off the donor so I don't have any worries there.
The only thing I didn't do was change the pressure plate; as the manual said, if there's no damage or scoring, then leave it? Could this be where I've gone wrong? Either that or I've got the wrong clutch on there. I just bought a replacement for a 1.6D Mk1 caddy (it's a 210mm). Maybe I should have bought the clutch for the gearbox?
What is the gearbox from?
yeah as far as I know you match the clutch to the gearbox
The box came from a 1.8 8V petrol
I've done a quick check and if I were to order one from say, eBay; the part numbers for clutches, so therefore the clutch itself are the same.
Schoolboy error
Haha, best get cracking pal!
Should be an easy fix though!
Should be nice and easy now!
what it could be is the clutch kit you bought actually had a mk3 2.0 8v or mk2 16v friction disc in it, these have a larger spline in the middle. so if you fit an 8v box it just rattles around!
turns out you were right Rubjonny, I've been sent a MK2 16V clutch, but thankfully, got the correct one coming out today on a 24hr.
16v pressure plate is stronger see, but that only applies to genuine vw kits sachs and the like use the same pressure plate for everything
From “NO DRIVE!”
I'm having a problem here with my Sachs clutch, the pushrod doesn't seem to push the pressure plate off the clutch enough. It's a brand new Sachs clutch kit. It works but its hard to get into gear and bite point is about 10mm off the floor.
It seems as if its not pushing the release plate and pressure plate far enough away. Could it be that the Sachs pressure plate springs are slightly (a few mm) further back? Making it hard to disengage the clutch? Or is it the wrong release plate, slightly deeper? Causing the same problem?
I'm thinking of just taking it all back off :-( and re fitting the genuine pressure and release plates. And just using the new Sachs friction discs. Could I be a victim of this 16v/8v buy and return thing??
