New Wheel Help
(In Topic #74240)
New Wheel Help
Hoping someone will know the correct measurements need to buy some wheels.Know the pcd is 100 and centre bore is i think 57mm but needing to know the best offset for front and rear.
fronts will be 7><14 and rears 8><14 with standard arches know the rear et will be a smaller number as theres more space there but does anyone know the best size ???
Tyre choice iam going for is 195 50 14 if i can find any any help appreciated thanks folks.
It is a difficult one to answer as it depends on your suspension height and travel too.
7x14 on the front is not too big at all and I would say ET 30 ish would be fine.
For the rears though 8 inches is quite wide, though with the 195's stretched on, you could probably get away with a similar offset of around ET 30.
My wheels are either ET 33 or 32 but are only 6 inch wide. The rears are nowhere near rubbing as the arches give quite a bit of clearance, though I think the fronts would be on the limit if it was any lower!
It's a tough call though and the best bet is to hope someone reads this post with a similar set up!!!
My Build Thread
is this for your polo mate? there aint as much clearance at rear on polo as golf, might be a bit of a beast actually im sure theres some law/rule thing about wheels sticking past your arches, i would try some different ones first before you commit yourself to buying any, dont really understand the et thing just from past experience i know wheels that didnt rub on a mk1 did rub on a polo, theres loads you can try here if thats any use,
paul
paul
tHANKS LADS SO CONFUSING AND DONT WANNA ORDER AND BUY BRAND NEW WHEELS TO FIND THEY DONT FIT oops caps.
Yes its a golf,polos a matchbox car deffo wont fit that.
Prob comes from sump so low but useable at mo but gap between arch n tyre tooo BIG dry sump not an option so up the profile of tyre up to 50 from 45 and a smaller et on rear to fill arch more here look n see what i mean.
http://homepage.ntlworld.com/kevin.yeoman/WebGalleries/GTIFestival2005/GTI%20Festival%202005%20006.html
See what you mean about the wheels - think it might look way better if it was lowered more…
This is interesting - did you speak to the owner?
My Build Thread
