new rims fitted what you think
(In Topic #141362)
Uploaded with ImageShack.us
if it aint broke dont fix it but betters allways better
i'm not a fan, but then its not my car and my opinion shouldnt matter
They look smart and different, the red picks out the trim in the front grill well but if the suspension was lowered a bit they would sit better IMO
Cheers Chris
Cheers Chris
Different! I saw a f plate BMW e30 on the m62 yesterday with these wheels on!
I think it weirdly works myself
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
LOOKS
THE NUTS
I LIKE IT
YOU KEEPING THE COLOUR OF THE CAR THE SAME OR DO YOU HAVE ANY PLAN TO CHANGE IT?????
YOU SHOULD PERHAPS DROP THE CAR A BIT…
THE NUTS
I LIKE IT
To pull the look off I think the car needs to be quite a bit lower
ok but its a knightmare now with drive scrapes allready plus it needs arches rolled a bit as i had to fit 5mm spacer on the rear or the center caps wouldnt fit due to stub axle cap,cars staying same colour i want to sort paint out thought about scoobie blue but wasnt sure
Are they 15s the rims?
Apply some negative camber. its when the tops of the wheels stick inwards more than the bottom like theyre tilted
Blue would look good or black.
Colour now is still good. Goes with the red grill surround I like.
It's like marmite
It's like marmite
15x7 et30 +5mm rear spacer 195 50 15
how can i change the rear camber i think ive seen some shims?
