Mystery noise at speed
(In Topic #96808)
Any ideas?
You may need to nip up the rear bearings to take a wee bit of slack out and see if that cures/helps it, rear bearings are far easier to change than fronts too :wink:
jack it up and check for play by holding top and bottom of wheel and wiggle the wheel back and forth, a small amount of movement (few mm) is ok as they are taper bearings and need the slack to run correctly, any more than that they need nipping up on the centre nut, if they have ever been over tightened it can cause premature wear and failure.
Thaks again.
