MOT fail on steering rack mount
(In Topic #76088)
Its welded up now but I had to take the rollbar off, the downpipe off (and make a tool for those spring clips to do it), the engine mount off and pull the rack back to get at it. Someone had tried to weld it before, but it had broken again.
I'm back on the road now, but I'll try to get the next MOT in August or September, when its not so cold under a car!
Big
My Build Thread
1983 1100 C
1983 1100 C
Not cracked yet, so no fails in that dept.!
My Build Thread
Real golfers don't play with clubs
Big - that would be ideal with a picture.
Its the bracket that carries the threaded studs, and the plate next to it. As you look from the front of the car, there is the bracket with the threaded studs near the steering box input shaft, and a plate to the left of it that is folded down beside the stud bracket. It appears that the weld between them - I guess it was spot welded originally - breaks, and when the wheel is turned as described before, the gap between the two increases. When I welded it I also welded the right hand flap of the bracket where it goes onto the bulkhead, and the flap at the left side where it runs near the rear engine mount studs.
Fixing this has also reduced the suspension knocks I get on uneven roads. (Changing the track rods & ends also helped.)
Big
Big
1983 1100 C
1983 1100 C
The pics are not that good since the camera wouldn't focus in the dark, but they should show you where to look.
Big
1983 1100 C
1983 1100 C
Lets see if that works.
The weld is between the plates on the left of the clamp strip.
Got to go, end of lunch. Big
