MOT fail on handbrake clip?
(In Topic #99077)
My sportline failed its MOT on one clip!? Aparently its the clip that holds the handbrake cable solid by where it enters the drum. Not having this clip is causing the cable to move back and forth thus giving weak rear offside breaking efficiency!
I have had a look on vagcat but i'm not 100% sure which bit I need.
I am thinking number 2, 23 or 24. 2 is listed as a plug? could this be the rubber grommet/plug that the cable goes through?
Any help greatly appreciated.
Tian :dontknow:
I'd double check everything and adjust the self adjusting wedge with a pointy screw driver thru a wheel bolt hole and then adjust cable inside at handle end.
If you can't figure the missing part from the diagram, then you could always look at the other side and see what's missing.
The tester said the clips went on the inside of the drum. Think he is getting confused with another car maybe.
Thanks for your help guys.
