mk2 16v brake servo upgrade.
(In Topic #127165)
If its the same servo, ie the 9" one, then you can use either master cylinder with it. People often give the recommendation to use a new master cylinder anyway, they're not that expensive and you have the reassurance the part is good and the seals are fresh. These days with parts consolidation etc, GSF and the likes will sell the "2 outlet" as a 4 outlet with 2 blanking plugs.
If the engine is a 16V then you need the 4 outlet and blank off the 2 on the right, due to the dizzy being in the way.
By the way, the 9" servo on Mk2 Golf/Passat doesn't work with the Mk1 Golf master cylinder, because the plunger goes into a different depth. So you need to fit both together, not one or the other.
