Mk1 knocking noise and it aint top mounts or cv joints, help
(In Topic #76715)
-Does the noise happen with engine speed, road speed, or unrelated to speed? If its affected by road speed then either Wheel bearing, Inner or Outer CV Joint.
-Affected by road condition? speed bumps, rough roads etc, pot holes?
-Does it happen 'constantly', or isolated knocks? (Indicating something suspension related).
-Does it happen/more/less depending whether turning right/left/straight? Try the classic turning on full lock either way.
Sorry,I wouldnt know the answer but those are teh kinda things you need to listen for
paul_c said
Loose or badly fitted exhaust system banging on bodywork or rear suspension?
This happened on my mk1, took me ages to figure it out. Just put some new rubbers on which were a bit stiffer and stopped it moving so much in cornering! problem solved!
1983 White cabriolet GTi
Funny you should mention that, because I had troubles fitting my exhaust. Basically, because it is slightly off straight, if you simply let the mid section hang, it will rest at an angle which is not a good enough fit and bangs. The trick is to raise the car enough so that you can get a good grip on it and tighten it up whilst holding in the proper position.
Then whilst playing under the bonnet one sunday afternoon, i happened to notice that the bonnet arm didn`t sit snuggly in the plastic retaining clip! Put another clip on..and lo and behold no more banging
So it`s an easy check, and it could save you a lot of time and hassle poking around the cv joints etc…..
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
