Mk1 Golf turbo gearbox problem
(In Topic #141683)
I have a Mk1 golf with a Mk4 1.8 Turbo engine converstion. I have used a mk2 16v gearbox which has failed for the second time. I understand that the best gearbox to use is the Mk4 1.8 Turbo, 02J 5 speed cable change box.
What I'm not sure about is that different 02J boxes have different codes, EVS, ECW for example.
Does anyone know which one I should use? Any suggestions on clutch/flywheel assembly would be great too!
John
box codes have different ratios.
you can check them out here.
Gear Up!
http://www.turbo-conversion.com/16v-turbo-conversion/16v-turbo-conversion/54
Mine was 108 but got some mk4 tdi flanges that use 100mm and bolt stright in.
Hope that helps
