Mk1 cab, want power steering
(In Topic #78200)
I have been told that the only thing that will 'go straight on' (I use this term loosely) is the power steering from a mk2 scirocco.
Is this correct, have you done it, and how long did it take ?
Carl.
TSR-Performance Ltd
Trouble is its expensive .
Also Buy this book it contains loads of info on conversions and more . Money well spent .
VW Golf and Jetta Restoration Manual (Haynes Restoration Manuals): Amazon.co.uk: Porter, Lindsay: 9781859604489: Books
Cheers.
and no-one really seems to know what bits are used in conversions, there was talk of a nissan bluebird rack being used ….?
I also read discussions about using electric power steering from the likes of a corsa…
there are a few possibilitys around so good luck and do keep us informed if you find anything
black 5 door mk1 GTD
mk1 scirocco Gli in bits
top mounts not worn - the Clipper was knackered and replacing these made one heck of a difference…….
correct tyre pressures……
correctly set camber and tracking….cannot be done correctly if top mounts are worn…..
…did not need power steering - nice and light even when parking……..
