mk1 brakes applying themseleves after 16v servo master cylin
(In Topic #105743)
Now the only difference that i can see that i've done is that on my master cylinder i've put the two brake switches on the right hand side instead of blanking them off and using even more ugly t-pieces. then the two hydraulic feeds to the brakes on the left, they still branch off on t-pieces and brake diaganolly.
All seemed fine when we finally got the car up and running we must of got at least a mile then the brakes started to bind to a point where the car didn't want to move and the only way we could get them to free up was cracking open one of the hydraulic lines.
any help would be appriecated and it's cool to laugh at me if i've done something pritty dumb.
In any case, sounds like the brakes are slightly 'on'. If you've already chopped the 10mm, then only a little more adjustment is needed. You can probably do all this with the cross bar. Loosen the 2 nuts on each end - beware, one of them (right, I think) is a reverse thread. Being a reverse thread means you can twist the cross bar to lengthen or shorten it. You want to lengthen it slightly - the levers are arranged so it pulls (ie to the right) to apply the brakes.
what i dont understand is that the first 7 or so times of using the brakes they were perfect then they ground the car almost to a hault.
they felt great when they were working a definate must upgrade but then they worked without applying the pedal.
so basically what your saying is that i didnt take enough off the end of the servo thread.
I hate cars, well.. no i don't but why does everything have to be the hard way.
But, the crossbar is adjustable. Just back it off a little bit and see what happens? Easy enough to take a pair of pliers and a 13mm spanner with you, in the glovebox?
in its maiden voyage (yesturday) the clutch was slipping as we had problems getting the clutch to enage and ballsed about with the slave untill it peed fluid all over the clutch. then the brakes binded and the car ground to a hault, then because the sump is so low and fradgile i grazed a slightly raised bit of ground and cracked the sump. All in the space of less than 30mins.
