mk1 BRAKES!!
(In Topic #112792)
mk1 BRAKES!!
Any ideas
Will
a good service and a well setup cross bar and rear brake adjusted properly should see the brakes work more than is needed. other options are a large master cylinder.
after that your talking mk3 brakes on the rear and bigger discs on the front.
Calipers seem to be operating properly dont know what else.
When did you last have the brakes serviced, eg fluid change, remove the drums and calipers and clean/inspect components?
thanks
