Mk1 ABF Gear linkage problem...HELP!
(In Topic #113163)
paul_c said
What car did you start out with and which bit is too short?
rubjonny said
did you fit all the mk1 linkage bracket and rods to the mk2 box? was the car a 4 or 5 speed before the swap?
Marshall16 said
I dont think all the brackets were all changed over to be honest. The origional mk1 gearbox was a 5 speed.
The entire Mk1 Golf linkage would need to be used, so if you're missing parts, or have the Mk2 items instead, then it won't work. I don't suppose you still have the old engine/box to look at? Or is it a case of trying to identify what's missing?
I just wondered if i used the rod from a Mk2 it would work.
