mk1 20v o2a gearbox and clutch problem help
(In Topic #114730)
The car has a couple of things I would like to sort
The gearbox and clutch release bearings are noisy and 3rd and 4th gears crunch when changing gear at speed. Have found volkswagenspares.com do a recon. 02a box with different ratio and uprated diff bolts for 395 +vat has anybody used one of their box's or could recommend an alternative.
Any ideas on the best clutch kit for the job running about 230 bhp
I also have a wheel rubbing problem the car has bbs rm 7.5" front and 8" rears, is quite low on H&R coilovers and the arches have been rolled. The rear wheels rub most times you accelerate and due to the country lanes around where I live (East Devon) they rub most of the time, is this usual with this set up or is it worth raising a touch or I hate to say changing the wheels.
Any ideas?
Andrew
As for clutch, just use a standard LUK VR6 clutch from the likes of GSF/ECP, more than capable of handling the power, just depends whether in the future you want to go for more power as I would question their ability in handling it, you should get a new release bearing with the clutch kit.
Can't help on the wheels but know that my 16x7s with 195/45 occasionally catch when loaded up and on a bumpy road.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
I am happy with the power so will use the VR6 clutch.
Thanks for the advise.
Can anyone help with wheels rubbing
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
I am expecting a K03s with a map and breathing mods to have no more than 220hp and currently looking for a clutch.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
My car runs about 230bhp qpeng stage 2 so will let you know how it gets on
Still looking for advice on rubbing wheels, 15"x 8" rear wheels can it be done without rubbing?
Have fitted the gearbox and clutch kit today. The clutch is not allowing the gears to engage, you a can select a gear with the engine off then start the car and the clutch just about works but is dragging with the pedal down.
I removed an 02a gear box and refitted a recond o2a gearbox and luk vr6 clutch kit.
The car has a hydraulic clutch and uses a willwood pedal box
we have bleed the clutch, no difference.
it is as if there is not enough movement on the release bearing
Any ideas
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
any ideas
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
I have just been to GSF and matched the clutch that we removed, it was a G60 clutch kit, so have bought it and will fit it on Tuesday hopefully.
I hope this does the trick as the E38 show is fast approaching.
we have checked the master cylinder by clamping the pipe and we get a solid pedal
Have fitted a new slave cylinder still the same but have been advised some slave cylinder are real pigs to bleed has any body had problems with Bleeding mk3 clutches.
E38 two days away a late night ahead!
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
For me thats a job for another day it will get me to my first E38 show as it is, so let the cleaning begin!
