Loud harsh crashing bang from front of clipper when going over potholes
(In Topic #156393)
Any thoughts on narrowing the fault down without just replacing all suspect items would be appreciated
Si
Currently running a VW Touareg altitude, Polo and 93 Clipper Cab, recently restored a 1303s Aircooled beetle and 11 window splitty
The noise is like a really harsh bang or jolt coming from the front end only. The set up seems to be a standard Macpherson strut set up. The measurements are as follows;Knowles said
What do you mean crashing noise, like a knocking, a jolt? Are you running coilovers/ lowered?
40mm from tyre top to wheel arch edge or 330mm from wheel centre to wheel arch lip.
Last edit: by durhamdubber
http://www.vwheritage.com/vw_spares_Top-strut-mount-kit-MK1-Golf-Scirocco-Jetta-171498329A_act_shop.product_pID_44863814_lang_EN_country_GB.htm?crumbStartPage=3&crumbStartRow=29
If shocks are suspect I wouldn't waste time just replacing the top mounts. Whilst you have it in bits might as well replace shockers.
Make sure you use Febi top mounts.
