knocking noise when i drop the clutch ?????
(In Topic #89372)
anyone had a knocking noise when you dump clutch and pull away ? it happens through all the gears….and its not the engine mounts and nothing feels loose down there !
got an awful feeling its the gearbox, but would appreciate any advice from the members.
'91 cabby Modified to suit - nut loaf
A6 Quattro - daily bread
have a look at your drive shaft bolts, make sure there tight
going to get it up on the stand and have a look at that tommorow foxymk1.
still waiting for the bently manual to turn up so don't want to too mad as its been 15 years since i last 'played mechanic' and don't want to screw up my pride and joy !
thanks for the info i'll let you know how it goes,
pedro
pedro
universal joints on the drive shafts - almost certainly. Get get a rebuilld kit from VW
neither it seems to be something else.
should probably said that the knock only happens once through each gear so as i first accelerate it knocks once then after changing to the next gear it knock again but only once for each gear change either up or down…this is gonna be a hair puller.
Bump- i've got the same problem…
Current Mk1's
1992 VW Citigolf CTi 1.8i (SA)
Previous MK1's
2006 VW Velociti 1.6i (UK)
1992 VW Mk1 Golf Clipper 1.8 carb (UK)
2000 VW Mk1 Citigolf Life 1.6i (SA)
1991 VW Mk1 Citigolf Sport 1.8 carb (SA)
1983 VW Golf Mk1 GTS 1.6 carb (SA)
Previous MK1's
COTM Team
I had this on a my old clipper once… sometimes when moving off or changing gear when the engine wouldn't be torqued it would squeak - a round metal gasket that goes in the join between the manifold and the downpipe needed to be replaced and that sorted it out…
COTM Team
wondered if it might be the exhaust, will have to check
chris :dontknow:
Shughy
Do you recall if this is the part you fitted to the exhaust?
https://www.heritagepartscentre.com/uk/171253115-sealing-ring-for-the-downpipe-to-manifold.html
Jez
Jez
Work on my Clipper
jez said
Shughy
Jez
WOW i cant remember what i did last week, nevermind 9 yrs ago… but yes had similar knocking on my first cabby ended up new rubber hangers, and downpipe gasket. Currently have similar fault with carb rocco, but also the down pipe to replace.
On the drive
Myvalver 89 GTi Grey mk2 16v
Thanks I got round to doing the gasket swap this year… All nice a quiet now
Work on my Clipper
