knocking front suspension
(In Topic #129965)
Ive just replaced a front dampner on my mk1 92 clippper convertable as it had a massive oil leak and am now getting a knocking noise from the same suspension. everything looks ok, the top mount looks nearly new and as tight as I can do it up. any ideas what could be causing it, there was no knocking before I changed the dampner? :dontknow:
DubPartz
Only other thing to check is that you refitted all the washers and spacers etc exactly as they came off.
miclj said
Only in a straight line I think
So it's definitely a knock and not a creak ?
DubPartz
plastic cover disc
large @22mm retaining nut
large flat washer
collar thats stop bearing being crushed
top mount
spring plate
smaller washer that sits on the machined recess on the strut
rubber bumpstop
plastic dust shield
"Early-1800" said
I've swapped front strut inserts where the insert is shorter than the strut and supplied with a big washer to place at the bottom or top so that it is clamped tight in the strut. Was the insert held tight when you did up the large nut at the top of the strut?
My thoughts exactly that the insert is loose in the strut, excluding any other parts that may have been wrongly assembled.
