Ive RUINED my steering/car. with coilover fitting.
(In Topic #74878)
im quite stuck, didnt know it was going to be this hard!
dont even know if i should ask for help
is it safe to drive to a garage like that?
i dont think either of the tyres are touching the suspension anymore but do rub badly on arches even when raised, oh its not all fun and games lol
gota wait til wednesday to get it done too
The problem is the offset of the Pirelli P's that you have.
With my wheels, even an offset of ET32 is tight with tyre and spring clearance. I believe the P's are ET38, meaning you might need a 5mm spacer minimum.
You can get over it by having neutral or slightly positive camber to be able to drive it to a garage if you have to. This may be a problem though as you say the tyres are already hitting the arches!?!? :?
Your tramlining and light steering are due to your tracking being out.
Droping the car on coilovers tends to change the angle on the steering arms quite dramatically. This causes them to pull the rear edge of the wheels in, meaning that the wheels are "toeing out". You need to lengthen the arms if you haven't already done so. Try and get your wheels pointing straight ahead. Looking by eye from behind the car, comparing to the rear wheels helps. This is how I have set mine up - never been near a tracking guage! 8O
My Build Thread
Re: Ive RUINED my steering/car. with coilover fitting.
de3660 said
i put coilovers on and now i think it "tramlines" the steering is REALLY light and will glide off everywhere
This sounds like the castor has gone from positive to negative. Try driving it backwards and see if the steering self-centres - this will prove that the castor is negative. I assume you have lowered the front and back an equal amount?
It depends how far the garage is, as to whether to drive it there or not. If its more than a mile or so, then I'd get it lifted and towed. You could make basic adjustments to stop it rubbing and put in positive castor, then take it easy on the drive to the garage.
You might need to purchase new tyres - expensive way of finding out! Were the tyres standard or wider?
standard tyres, and size.
well since that post ive raised the car up equally (was lowered equally all round, and inch from the bottom of the coilover)
the tyres no longer rub on the springs, so will attempt to drive to a garage 2moro, yeh it will be alot more than a mile, cant really afford to tow it.
no way from me looking at it will i be able to adjust it even close to correct, so i did wot i can so its not touching the springs.
also every garage/performance garage has told me never use spacers, they say will tramline again etc.
And of course, if you want to adjust the ride height at any time in the future, you'll have to go through this procedure of getting the wheel alignment done again…..so I hope you set it at a height you can live with!!! Got any speed bumps or kerbs in your local area??
ill raise it enuff and hope they can do a good job, are spacers something to stay away from then? or something ill need.
when/if i get new rims/tyres ill have to do it again wont i, like 13s or 14with lower profile. what about wider tyres, im hoping they start from there and go out not, go back in a bit and will cause rubbing again.
well im going to try and get it done 2moro will let u know how it goes, and how much it cost!
If you think they are going to rub on the inside, before the outside, you'll need spacers as you go wider.
Maybe there is scope for everyone to pool thier resources together and someone could start a list of achievable wheel size, tyre size, offset (ie spacers) and amount lowered?
I don't think this would work mate as the different manufacturers of Coilover kits may have different measurements and dimensions etc. Also, depends on wheels tyres, camber, even if it is a poorly fitted wing (could give more or less clearance on the outside of the tyre)
My Build Thread
That is what "Offset" is mate.
If you don't understand what it means, do a bit of research (Google it) to find out as this is THE most important thing to consider when buying after market wheels.
My Build Thread
paul_c said
This sounds like the castor has gone from positive to negative…
…make basic adjustments to stop it rubbing and put in positive castor,
You mean Camber I think.
Castor is fixed on a Mk1 unless you use racing strut tops…
My Build Thread
Nope, I meant castor. Of course, camber and castor are interrelated……
Aquaplanned and nearly crashed it after 1 hr of driving it!
Raised it by 1" and got it set up properly (except camber was limited to -3degrees due to lack of adjustment on the shock body which is fine) and now she is v good!
S
Handles FAR better than it ever did b4, so im guessing the person b4 me hadnt had it set up right, (why they were badling on one side and steering was heavy)
so now with loads of tred and (what feels like power steering) am having a good time.
felt like driving on ice all the way there, dont really wana go through that again.
cheers for all the help again as usual.
report again later with pics or something.
Welcome to bone shaking ride quality! :mrgreen:
My Build Thread
dont like the speed bumps tho, doing less than 10mph (the gauge doesnt go lower than 10 does it) lol so its prob bout 2mph or i hit the bottom.
had to put standard seats back in because of it was too hard with buckets, (WHICH ARE NOW FOR SALE, with or withought mk1 golf subframes)
put another set of wheels with a lower offset and it clears it so i can get it aligned 2moro morning
haha
