Issues selecting 2nd only when cold
(In Topic #157862)
So this is a bit of an odd one I can't figure out.
From cold, when changing from 1st to 2nd it will crunch into gear, only 1st to 2nd, however after about 5 mins of driving its fine, no trouble at all. Both my wife and myself have had the exact same issue.
Any ideas?
The crunch from 1st to 2nd is a common problem with these gearboxes, it means the syncromesh if failing. An oil change might help get a bit more live out of the gearbox the oil is often neglected and never changed.
Handy tool to remove the drain and filling plugs if you dont have a 17mm allen key
http://www.ebay.co.uk/itm/Draper-1x-17mm-Hexagon-3-8-Square-Drive-Drain-Plug-Key-Professional-Tool-/350698932366?pt=UK_Hand_Tools_Equipment&hash=item51a749088e
As long as you're gentle with it when cold then the problem shouldn't get any worse
1.8T CABBY
1.8T CABBY
Guest user
