I've broken my nipple!
(In Topic #117986)
can't find the nipple but looks like it's unfixable. Look in haynes tells me I just need to replace the wheel cylinder but there are three types of drum???? Automatic, cable, manual?
Haven't a clue what I'm after, are cylinders the same for all types of drum?
Also, how do I get the drum off? as I was going to do this about 2 weeks ago and couldn't see how?
Thanks in advance for any help, will post on my resto thread for the little else I did tonight but cry about the catastrophe of my nipple….It was going so weeeellllll!
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
to remove your drum take off the hub cap, remove split pin and locking cap, undo nut and pull off drum(i needed the help of a large flat headed screw driver for one side).
I swapped my wife for a Golf GTI!!!
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
novocaine said
for what it's worth replace the cylinder.
Ya got there first :wink:
changed the cylinder but not sure I've got the right one.
I have the "wedge type drum" on a late 83 gti cab, I am 99% sure I don't have a brake regulator (I spend an hour looking for it after fitting my new coilovers).
The cylinder I got is for an 83 gti with 17.5 cylinder? and it physically fits, is that okay, or have i fitted the wrong one?
thanks in advance for any help.
also, after taking apart the drum and removing the shoes, replacing the cylinder. I put everything back exactly as it came off and now my brakes are no longer and even my handbrake doesn't work, suggestions??
Cheers.
sorry that was mean
you need to adjust the rear brake so it's actually going to touch the drum again. theres a how to in the haynes. i think it involves a screwdriver though one of the wheel bolt holes but it's been a while.
It's cool man, you're always mean I keed I keed.
I need to rebuild my rear brake drums. Like yours, my nipple has broken off on one side (sounds a bit wierd to say that out aloud).
Is there a kit available? what would be included in it? and how much would it cost? does GSF do it?
I'm rebuilding an 82 gti and the brakes need attention. Help!
'82 Mk1 GTI
'86 Mk2 GTI
'06 Mk5 GTI
~What can I say? I'm just a GTI lover….~
My '82 Mk1 GTI Project
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=60383
'86 Mk2 GTI
'06 Mk5 GTI
